varunme
Advanced Member level 3
My code for interfacing RTC through software i2C not working in real hardware, but it does in proteus simulation
it shows invalid characters for date and time
unsigned short skp;
// Software I2C connections// Software I2C connections
sbit Soft_I2C_Scl at RC3_bit;
sbit Soft_I2C_Sda at RC4_bit;
sbit Soft_I2C_Scl_Direction at TRISC3_bit;
sbit Soft_I2C_Sda_Direction at TRISC4_bit;
// End Software I2C connections
// LCD module connections
sbit LCD_RS at RD2_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_EN at RD3_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D4 at RD4_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D5 at RD5_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D6 at RD6_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_D7 at RD7_bit; // for writing to output pin always use latch (PIC18 family)
sbit LCD_RS_Direction at TRISD2_bit;
sbit LCD_EN_Direction at TRISD3_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
char seconds, minutes, hours, wday,day, month, year; // Global date/time variables
char keypadPort at PORTD;
void Read_Time() {
Soft_I2C_Start(); // Issue start signal
Soft_I2C_Write(0xD0); // Address PCF8583, see PCF8583 datasheet
Soft_I2C_Write(0); // Start from address 2
Soft_I2C_Start(); // Issue repeated start signal
Soft_I2C_Write(0xD1); // Address PCF8583 for reading R/W=1
seconds = Soft_I2C_Read(1); // Read seconds byte
minutes = Soft_I2C_Read(1); // Read minutes byte
hours = Soft_I2C_Read(1); // Read hours byte
wday = Soft_I2C_Read(1); // Week Day not use
day = Soft_I2C_Read(1); // Read year/day byte
month = Soft_I2C_Read(1); // Read weekday/month byte
year = Soft_I2C_Read(0); // Read Year byte
Soft_I2C_Stop(); // Issue stop signal
//-------------------- Formats date and time
void Transform_Time() {
seconds = ((seconds & 0xF0) >> 4)*10 + (seconds & 0x0F); // Transform seconds
minutes = ((minutes & 0xF0) >> 4)*10 + (minutes & 0x0F); // Transform months
hours = ((hours & 0xF0) >> 4)*10 + (hours & 0x0F); // Transform hours
day = ((day & 0xf0) >> 4)*10 + (day & 0x0F); // Transform day
month = ((month & 0xF0) >> 4)*10 + (month & 0x0F); // Transform month
year = ((year & 0xf0) >> 4)*10 + (year & 0x0F); // Transform year
//-------------------- Output values to LCD
void Display_Time() {
Lcd_Chr(1, 6, (day / 10) + 48); // Print tens digit of day variable
Lcd_Chr(1, 7, (day % 10) + 48); // Print oness digit of day variable
Lcd_Chr(1, 9, (month / 10) + 48);
Lcd_Chr(1,10, (month % 10) + 48);
Lcd_Chr(1,14, year / 10 + 48); // Print year variable (start from year 2010)
Lcd_Chr(1,15, year % 10 + 48); // Print year variable (start from year 2010)
Lcd_Chr(2, 6, (hours / 10) + 48);
Lcd_Chr(2, 7, (hours % 10) + 48);
Lcd_Chr(2, 9, (minutes / 10) + 48);
Lcd_Chr(2,10, (minutes % 10) + 48);
Lcd_Chr(2,12, (seconds / 10) + 48);
Lcd_Chr(2,13, (seconds % 10) + 48);
char Ds1307_HexFormat(char val){
//int xval=0;
return((val/10)*16)+(val%10);
//return xval;
void Update_DateTime(int val,int loc){
//Location
// 0-SS 4-DD
// 1-mm 5-Mn
// 2-HH 6-YY
// 3-Wd
switch (loc){
case 0: val=0x00; break;
case 1: if (val>59) val=0x00; if (val<0) val=60+val; break;
case 2: if (val>23) val=0x00; if (val<0) val=24+val; break;
case 3: val=0x00; break;
case 4: if (val>31) val=0x01; if (val<1) val=31+val; break;
case 5: if (val>12) val=0x01; if (val<1) val=12+val; break;
case 6: if (val>99) val=0x00; if (val<1) val=99+val; break;
Soft_I2C_Init(); // Initialize full master mode
Soft_I2C_Write(loc); // Start from address 0 (configuration memory location)
Soft_I2C_Write(Ds1307_HexFormat(val)); //Hours Location (hh)
Soft_I2C_Write(0xD0); // Address PCF8530
Soft_I2C_Write(0); // Start from address 0
Soft_I2C_Write(0); // Write 0 to configuration memory location (enable counting)
void Disp_tmplt(){
Lcd_Cmd(_LCD_CLEAR); // Clear LCD display
Lcd_Out(1,1,"Date:"); // Prepare and output static text on LCD
Lcd_Chr(1,8,'.');
Lcd_Chr(1,11,'.');
Lcd_Chr(1,16,'.');
Lcd_Out(2,1,"Time:");
Lcd_Chr(2,8,':');
Lcd_Chr(2,11,':');
Lcd_Out(1,12,"20"); // start from year 2010
//------------------ Performs project-wide init
void Disp_Mode(int xM){
switch (xM){
case 0:lcd_out(2,15,"SS");break;
case 1:lcd_out(2,15,"MI");break;
case 2:lcd_out(2,15,"HH");break;
case 3:lcd_out(2,15,"WD");break;
case 4:lcd_out(2,15,"DD");break;
case 5:lcd_out(2,15,"MO");break;
case 6:lcd_out(2,15,"YY");break;
default :lcd_out(2,15," ");
void Init_Main() {
trisa=0;
porta=0;
TRISB = 0;
PORTB = 0xFF;
TRISB = 0xff;
ADCON0=0;
ADCON1=0;
Keypad_Init();
Soft_I2C_Init(); // Initialize Soft I2C communication
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
Disp_tmplt();
void main() {
Delay_ms(500);
Init_Main(); // Perform initialization
while (1){
Read_Time(); // Read time from RTC(PCF8583)
Transform_Time(); // Format date and time
Display_Time(); // Prepare and display on LCD
delay_ms(1000);
