How to setup a Zigbee peer-to-peer 2.4GHz network
perplexious
I have got a task to design n establish a 2.4GHz Zigbee peer-to-peer network... How do I design it ?
Are you going to use ZigBee XBee modules?
If so, I would recommend buying a pair of XBee Series 1 modules. They usually require no additional setup and will successfully form a connection out of the box.
You can code and test your design for a direct serial connection between peers and replace the physical serial connection with the ZigBee XBee Series 1 modules.
I have posted numerous examples and tutorials in the group:
broken link removed Embedded Wireless Networks - WiFi, ZigBee, MiWi, 802.15.4, Bluetooth & RF
The XBee series 2 are designed for wireless mesh networking as such they require considerable setup or initialization before two peers can be connected.
Other OEM ZigBee modules require varying amount of setup/initialization and coding, some require the use of supplied libraries.
Let me know if you have any additional questions.
BigDog
Can u tell me how the block diagram of a Zigbee peer-to-peer network will be? Can we use Microchip's Zigbee module instead of Xbee module...which one is much easier to be used?
I'm not sure I understand the question. If the network has only two nodes, then there is only one possible diagram.
Microchip's ZigBee modules have an SPI interface and require the use of a software library package. They also require the use of the PIC18, PIC24 or PIC32 families and are not supported by the PIC16 families.
So the ZigBee XBee Series 1 modules are much easier to implement.
BigDog
In terms of a block diagram does it actually mean that we have an input connected thru a RS232 connector to the Xbee module transreceiver den from the transceiver another RS232 to the microcontroller n to the output ?Is the microcontroller attached to the Xbee module o do we have to construct a separate circuit? where do i find examples of source codes for Xbee module? Thanx a million
The XBee modules are 3.3V devices, therefore a separate regulated supply or breakout board is required in the PIC is running at 5V. A breakout board also simplifies the task of breadboarding the XBee modules, due to the fact they have a 2mm pitch rather than the more common 2.54mm pitch.
XBee Explorer Regulated Breakout Board
XBee adapter 5V Board
If your design requires interfacing an XBee module to a preexisting RS-232 port, such as a PC RS-232 Serial Port, you will need to implement RS-232 transceiver or an UART to USB bridge adapter board.
XBee to USB adapter board
XBee Explorer USB Board
Establishing a connection to a MCU, such as a PIC, can be made directly to the MCU's UART.
Xbee Wireless Interface to PIC Tutorial
For additional design and code examples, as I mentioned previously, reference the broken link removed Embedded Wireless Networks Group.
BigDog
Xbee modules actually comes with a transmitter and receiver which is standalone...o izit a transceiver...Xbee modules can interface with Microchip's PIC rite? Can Microchip modules interface with other microcontroller families other than PIC's?
Hi, I'm a beginner and trying to set up a zigbee network, I have done some research and there seems to be lots of different hardware. I am not sure which are needed to establish a working network but is it possible to get a zigbee usb as the controller(transmitter) and a zigbee plug(receiver) on the other end where a device can be plugged into?
Sorry, if I am not very clear but any answers will be appreciated. Thanks
