Ravinder487
Full Member level 3
- Joined
- Jul 9, 2010
- Messages
- 169
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Bangalore, India
- Activity points
- 2,469
But for 2-stage opamp slerate is determined by ratio of compensation capacitor and tail current of first stage rather than what u said,correct me if I'm wrong.uhm...
i think that you can first fix your slew rate..
you should have a slew rate of 1V/ns or greater, equal to 1 GV/ s. So, the current which the voltage-to-current converter has to source when a large signal applied is simply I=C*dV/dT = 50e-15*1e9 = 50e-6 = 50 uA. This is the maximum output current you have to set for your OTA. This current can be higher if you need a greater slew rate. 50 uA is the "minimum maximum" current.
Yeah you are right,If OTA is slewing then settling time is soley dependent on slewrate(and hence on voltage step).Else it is dependent on phasemargin(may be on Bandwidth).However, i think that the settilng time spec is for a given voltage, isn't it?
Hi all this is problem I'm facing In designing OTA.I got slewrate of 10V/uS using bias current(Id) of 45uA.So I've increased the Id by 8 times then I need to increase W/L of second stage so that gm/Cgs of second stage is 10 times the gain bandwidth.If I increase W/L so will its Cgd increases(and gets added to Cc).So my slewrate(Id/Cc) isn't increasing by 8 times.
So it seems,to me,next to impossible to reach a slew rate of 1GV/S!!!!Please help me.
