augre
Newbie level 3
- Joined
- Dec 1, 2012
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,303
Hi I am designing a two stage MOSFET amplifier.
The first stage is a Common-Source, the second is a Common-Drain (Source follower):
https://www.circuitlab.com/editor/#xb82e5
The circuit has to be output and input independent as much as possible. So as low magnitude error as possible at a source with non-trivial output R and for small loads.
I would like ideas on additional stages or changing something on the design to reach the most load independent result!
Thank you!
Thank you!
