2- Line LCD-HD44780U-Return Home
Ajish Babu S
Member level 1
Trivandrum,Kerala,India
Hi
I use 2 Line LCD and HD44780U as LCD controller. If value two writes to control register that is return home then what happens second Line of LCD.I have no hardware I want to write a simulation model for LCD.
With regards
Ajish Babu S
When you send a home command to lcd the cursor will point the first character of first line. Nothing will happened to the data displayed on lcd
Hi
Thanks for reply
I got the LCD simulator from that link.
It working . It need some scripting .
dilraj did you test it in real hardware.
with regards
Ajish Babu S
U can Simulate the LCD using the Proteus Software . In that u can simulate your code .,
