aot
Newbie level 6
I have a small, cheap (bought from ebay) 2.4GHz video transmitter which I am using with a small CCTV camera to transmit back footage from a quadrocopter. The reception isn't fantastic, it only cost about £5 so it's not a huge issue, but before I buy something else I may as well see what can be done.
The antenna is uses is a short monopole piece of wire sticking up from the circuit board. Can this be replaced, for example connect some coax to it and have a sma connector on the end for connecting to standard 2.4GHz antenna's, or is it likely to have some matching network/other things to tune/electrically lengthen the antenna so the output isn't 50ohms? All the components are so tiny, it's difficult to tell!
I was thinking that it's probably not going to be possible, but I came across this: XRF wireless UART serial data module XBee shape arduino | eBay UK
Yes it's at a lower frequency (868MHz), but surely the principle is the same? You will notice in the picture that either a small wire antenna is attached, or a SMA socket, and presumably it's easily interchangeable.
Thanks,
Aaron
When I think about it wifi antenna's seem to all use
Thanks,
Aaron
