leolegend
Newbie level 2
From: nRF24L01 Module Demo for Arduino | ElecFreaks
For this you need two Arduino boards and two RF modules, one to transmit and the other to receive.
The nRF24L01 module is worked at 1.9-3.6V voltage level, if you use standard Arduino board, you should use the Arduino board’s 3.3V pin(VDD3V3) to provide power for the nRF24L01 module. Please note, not use 5V pin(VDD5V) to provide power, which may destroy it.
The Demo pins to Arduino as below:
GND–GND, VCC–3.3V, CS–D8, CSN–D9, SCK–D10, MOSI–D11, MISO–D12, IRQ–D13
Download the code below into the TX Arduino (transmit) — This code will drive the nRF24L01 module to send out data form 0×00 to 0xFF .
Note, between the write TX_FIFO and clear RX_DR or TX_DS or MAX_RT interrupt flag, would better not serial print anything, which maybe case ACK failed.
Download the code below into the RX Arduino (receive) – This code will drive the nFR24L01 module to receive the data that transmit form the TX module and print it to serial port.
Note, clear RX_FIFO must bellow Read_FIFO
Now power on both Arduino , and connect the RX one to PC via USB. Open the IDE serial port monitor , change the baud rate to 9600 bps , and you can see the data that received.
More informations about RF module: nRF24L01 Module Demo for Arduino | ElecFreaks
void setup()
SPI_DIR = ( CE + SCK + CSN + MOSI);
SPI_DIR &=~ ( IRQ + MISO);
// attachInterrupt(1, _ISR, LOW);// interrupt enable
Serial.begin(9600);
init_io(); // Initialize IO port
unsigned char status=SPI_Read(STATUS);
Serial.print("status = ");
Serial.println(status,HEX); // read the mode’s status register, the default value should be ‘E’
Serial.println("*******************TX_Mode Start****************************");
TX_Mode(); // set TX mode
void loop()
int k = 0;
for(;;)
for(int i=0; i<32; i++)
tx_buf[i] = k++;
unsigned char status = SPI_Read(STATUS); // read register STATUS's value
if(status&TX_DS) // if receive data ready (TX_DS) interrupt
SPI_RW_Reg(FLUSH_TX,0);
SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH); // write playload to TX_FIFO
if(status&MAX_RT) // this is retransmit than SETUP_RETR
SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH); // disable standy-mode
SPI_RW_Reg(WRITE_REG+STATUS,status); // clear RX_DR or TX_DS or MAX_RT interrupt flag
delay(1000);
void setup()
// attachInterrupt(1, _ISR, LOW); // interrupt enable
Serial.begin(9600);
Serial.println("*****************RX_Mode start******************************R");
RX_Mode(); // set RX mode
void loop()
for(;;)
if(status&RX_DR) // if receive data ready (TX_DS) interrupt
SPI_Read_Buf(RD_RX_PLOAD, rx_buf, TX_PLOAD_WIDTH); // read playload to rx_buf
SPI_RW_Reg(FLUSH_RX,0); // clear RX_FIFO
Serial.print(" ");
Serial.print(rx_buf[i],HEX); // print rx_buf
Serial.println(" ");
delay(1000);
