abhishek.vnit
Newbie level 6
Patch antenna for RFID
Hi to all,
I am presently designing an antenna for 2.45 GHz .. I need to design antenna having as small size as possible and as high gain as possible..
I will be using a microstrip patch antenna. For 2.4 GHz, Half wavelength is apprx. 125 mm .. Is it necessary that patch dimensions have to be approx. equal to this value???
I have seen some examples where various patch shapes were designed to have reduction in size.. (Techniques such as folding)... This made me wonder what about the RFIDs which are being used.. If they used antenna with lengths (dimensions) of 5 cm!!!! I also came to conclusion that the dielectric permittivity must be kept high (~10) to reduce size... My aim is to investigate if a patch antenna array of very small length (around 1 cm) could be used to harness the ambient RF power.
It would be of great help if anyone of you could point to papers where design of small antennas for 2.4 GHz is given.I would like to have a patch antenna of dimensions less than 1 cm which works for 2.4 GHz.. i do understand that using a high dielectric would introduce impedance matching problems, but I could do with a high feed point impedance. Could you clarify on this???
Thanking you.
Abhishek.
Hi to all,
Thanking you.
Abhishek.
