2.4 GHz modulator - what type of it should I use?
blekot
Junior Member level 1
2.4 GHz modulator
I need modulate carrier 2.4GHz by signal bandwidth 7MHz, transmit-receive and demodulate. What type of modulation should I use. I want to get simple and low cost device.
If you have any suggestions, scheme I will be grateful.
Thx, Blekot
ptoo30
Member level 3
Member level 3
modulator
For 2.4g,it is common to use doublebalanced mixer(gilbert ). TDA6131xs is one of the solution.
Needbias
Full Member level 1
use two double balanced mixer to construct a new IQ mixer and you will get the solution
Jackal
Member level 2
Member level 2
Russia, Krasnodar
IQ modulator
Try Analog Devices or Maxim products
Links are:
szabatin
Newbie level 1
Newbie level 1
Re: IQ modulator
Is this analog or digitital signal?
