UroBoros
Advanced Member level 2
- Joined
- May 5, 2004
- Messages
- 642
- Helped
- 19
- Reputation
- 38
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Cochin - India
- Activity points
- 6,463
I need to control a a load (heater) using a triac. I need to use something like pulse skipping modulation to control the heater. The Microcontroller board and Analogue part will be working from a +12-0 -12V transformer based power supply. I think I can use the DC before filter with a transistor arrangement to trap the zero crossing point for microcontroller. MCU drives the trac using a zero crossing type opto for isolation. I have no plans to connect the neutral or ground from outside to my system. My understanding is that when opto is used no such live interaction is needed. Hope my plan is clear.
My confusion is, on searching I read about cold side switching , hot side switching, phase side etc. Also in some cases only one resister is connected to the gate of Triac via opto. Some circuits use another resistor from the other AC terminal also.
Also in this situation is the load connecting side or phase neutral connection is important? Will triac act like a conventional switch for AC or 'polarity' is important?
Thanks
Thanks
