AWR Microwave Office help
miky
Newbie level 6
Hello!
I do not have much experience with MV AWR office if someone could help, I'll be grateful,
Coupling between coils in the near field UHF range,
I will post a photo below what I have done already in MWO EM Structure
I'll be grateful for all help I can get to simulate this.
How can I draw the loop in AWR mw Office as easy as possible or someone could send me an example of such a antenna.
How to draw the coil with AWR MW office, and simulated ?
I'm in the range of 800MHz to 1GHz
many thanks;)
Hello miky,
You can easily construct RFID Coils in AWR MWO using Microstrip component Spiral models usch as
Rectangular Microstrip Inductor without Bridge (EM Quasi-Static): MRINDNBR....
See the attached document for more details on how the coil is generated & can be simulated...
You can extract this to EM structure for accurate modelling....
---manju---
  • Rectangular Microstrip Inductor Coil.pdf
Hello
somehow this does not work I have tried it is always some error ..
  • test antenna.rar
Hello miky,
Your EM extraction setup is wrong, first of all set up the dimension units to um instead of mm & try to use the MRINDNBR model and also make sure your schematic has MSUB, EXTRACT, STACKUP, blocks placed as shown in the attached picture & then do EM extraction & simulate for antenna analysis....
---manju---
    V
thank you many times
I hope that I am now wide
---------- Post added at 16:20 ---------- Previous post was at 15:24 ----------
The question now,,if I now Here are some of reel change, then stops working,I need something bigger coil working as antenna coil.
the chip supplied with energy.
so etwas will ich nach simulieren
https://obrazki.elektroda.pl/92_1289402360.jpg
hello manju
how can I coupling coils with Mw Office constitute,,I have so tries but it does not work the,,how do you do that I hope you have some time to help me
  • loop antenna.pdf
  • AWR Projects.rar
Hello Miky,
You can create two coils in one schematic & add the MGAP element with the coils spcing i.e. distance between the coils & properly arrange the layout & then finally extract as EM structure....
I have created two schematics one a single coil antenna for EM extraction & the other two coils for coupling analysis with 5mm spacing as an example...
see the attached modified MWO project & screen shots ...
---manju---
  • Coupling_Manju.zip
