ztledlights
Newbie level 3
Technical Specifications:
Model: ZT-D160-1811A
Shade dimension: D160*H80mm
Rated power: 18w
Lamp beads: 18pcs
Housing material: PC
Input voltage: 85-264VAC/DC,50-60Hz
Efficiency: 0.80
Luminous flux: 1500lm(warm white), 1700lm(neutral white and cool white)
Viewing angle: 15/18/30/45/60 (optional)
Color rendering index: 75±5Ra
Color: Warm white/White/Cool white
Color temperature: (3000K-3500K),(4000K-4500K), (5500K-6500K)
Working temperature: -20℃ - 45 ℃
Luminous efficiency: >70lm/w
Down light is a kind of high- power LED light with low power consumption, low heat radiation, high efficiency, low attenuation and without ultraviolet and infrared. It can save energy as much as 80%, and has a more stable performance and better cooling system. Besides, its lifespan is over 50000 hours. With the low voltage constant current drive, uniform brightness, no flicker, no glare, uniform brightness, luminous soft, smooth, continuous, close to natural light, the down light can be embedded in the ceiling, and it is very suitable for decoration and illumination.
For more information, please visit **broken link removed** or contact elina@ztlights.com.
skype: ztlights-elina
Rated power: 18w
Lamp beads: 18pcs
Efficiency: 0.80
