18f452 software reset in mikroc pro
madhushan90
Newbie level 6
Can anyone tell me how to reset 18f452 micro controller in mikro c pro code.
thanks.
hello
i think this PIC has no reset instruction as new one.
if your init sequence is correct , it means all I/O are initialised , not by default value on (hardware ) reset
you can use a
_asm
goto 0x0000h // if no bootloader !
_endasm
or maybe use an output like RA4 open collector ,in parrallele with MCLR (reset)
and write 0 on it. => Hardware reset. ( a pull up resistance is needeed for the MCLR pin ie: 10K to VDD)
hello
you can use a
_asm
_endasm
Thanks paulfjujo, but i can not find out implement this in mikroc pro. Can anyone help me to figure it out. regards
you can implement
 _asm
_endasm
in mikroC
---------update------------------
yes this code is not working in mikroC
void main() {
    TRISB = 0x00;
    PORTB = 0x00;
    PORTB.F0 = 1;
    Delay_ms(3000);
    asm {
        goto 0x0000    // if no bootloader !
    Delay_ms(3000);
Check this
http://www.mikroe.com/forum/viewtopic.php?f=88&t=28198
I think your code is working. But it can not identify because it doesn't do any change to the state of led. try this and you can find out it is working.
void main() {
    TRISB = 0x00;
    PORTB = 0x00;
    PORTB.F0 = 1;
    Delay_ms(3000);
    PORTB.F0 = 0;
    Delay_ms(3000);
    asm {
    Delay_ms(3000);
regards.
