I want to comunicate my pc with TCP/IP protocols. My hardware will contain 18F452 and RT8019. Is it ok for TCP/IP comunications?
I ask this question because, I have had alot of information onthe pic. RS232 is not enough to tranfer this information(baud:115200). So, I decided to transfer these with TCP/IP.
I would use a 18F6720. It has 128K of rom and 3840 bytes of ram. Comes in a 64pin TQFP package so is about the same size, but you could implement a 16 bit interface and have more ram for a buffer.
If you are mean to get the driver information of RTL8019, here below
AN475: DP8390 Network Interface Controller: An Introductory Guide DP8390D/NS32490D NIC Network Interface Controller
AN874: Writing Driver for the DP8390 NIC Family of Ethernet Controllers
AN886: The Operation of the FIFO in the DP8390, DP83901, DP83902, and DP83905
AN937: Loopback Diagnostics Using the DP8390/901/905
Search at google first, if still get it tell me.
And, we are defining the MAC address at the TCP/IP stack at link layer. Go study the TCP/IP stack for your understanding.
I didn't mean where can I get driver information.. I meant where can I physically buy the part. I find that it's a hard part to find, and I cannot buy it in small quantities.
If you want to buy a single chip I can recommend www.voti.nl
The chip costs almost 10 euro (9.37 to be exact) but you can purchase a single chip if you want.
Microchip did offer you their free TCP/IP stack. Now the C18 compiler is offered as Student Edition and you could use it after expire of 60 days try period.
Added after 59 seconds:
Also check their demo board. You can find the schematic in the user's guide.
