18bit ADC snr=93db is it good?
allan_guo
Junior Member level 3
I think 18bit adc, SNR must be larger than 18*6.02+1.** may be better than 108db.is this ADC good?
the other question:INL(maxium)=2LSB, can this cause missing code?
I just see a datasheet:it says no missing code with INL=2LSB.I am confused.
A beginer in ADC, thanks everyone.
sunking
Advanced Member level 3
of course it is a good adc. only its snr is not very high.
for second, INL = 2LSB may be no missing code.
allan_guo
to sunking: INL=2LSB I think will cause missing code, can you explain?thanks very much
maxwellequ
Full Member level 3
Full Member level 3
Having INL=2LSB does not necessarily cause missing codes. To check for missing codes you have to look for the DNL instead, and see if it is larger than -1.
Rgds
Shaber_Mezbah
Newbie level 6
Newbie level 6
You have to see your design specification to find the snd requirement for your application. you must check your input signal's band of interest.
If your system needs 18bit of dynamic resolution then you have to go for 108dB SNR ADC.
Static performance like DNL mainly tells you about Missing code (DNL<+-1).
The reason behind the bad value of SNR is due to its larger INL.
    allan_guo
allan_guo
I see.thanks every one
Added after 10 minutes:
Do you mean: when SNR is good ,then the INL is good.just like sunking's curve,the vout will come near to the ideal curve. that's the better the SNR,the vout will more like the ideal vout.
Shaber_Mezbah
Newbie level 6
Newbie level 6
yeah.. as the name implies:
INL: integral non-linearity.
this non-linearity is also coming in SNDR (peoples usually call it SNR)
bowling
Newbie level 2
Newbie level 2
I doubt that. I think DNL implies SNR, and INL represents SDR, SFDR. In general, noise performance reflects in DNL, while distortion problems degrade INL.
Second, INL of 2 doesn't say anything about missing codes. Only |DNL| > 1 would cause missing codes.
flatulent
Advanced Member level 6
Middle Earth
The data sheet may mean the ratio of a full scale sine wave to all noise+distortion. This is the SNDR mentioned above.
