how to dwnld a vhdl code on xilinx sprtn3e Kit using fpgaAdv
enga3b2
Junior Member level 1
Hello All
Kindly I wanna Know how to download a vhdl code on xilinx spartan 3e Kit using fpga advantage
I currently use FpgaAdv7.2 and I have to copy the vhdl code again and paste it in anew project in ISE to download it on the kit. I'm new to this category and need to know a way to download my code directly on the kit using FpgaAdv tool.
Thanks
Re: how to dwnld a vhdl code on xilinx sprtn3e Kit using fpg
Even with FPGAadvantage you need xilinx ISE. to create and download bit file.
refer to manual of your kit about how to program it, or specify which kit you are using, so this forum can help you.
along with your vhdl/verilog code you also need to have a UCF file In which one has to specify various pin constraints which agian depends on which board you are using.
there are various ways/modes to program the kit.You need to set some jumpers and connect download cable(hope you have one) to the kit.
you can use the Impact utility available with xillinx program.
so, the only way to download a code is by using ISE.
i use spartan3e. i had already downloaded a test code of xor operation before but i have another problem
the kit has only 4 switches, and i don't know a way of how can i test a code with 10 input bits for example, kindly help.
for testing your code...
1. use your code as a component in a top module.
2. In the top module on press each of one of the switch apply one vector to your Design under test and on getting the expected output switch on some led available on your design...
This is not a good way to verify a code... as you are adding extra logic with your dut, but it will help a beginner to get start with and get a feel of how things are.
