justice_md5
Newbie level 3
- Joined
- Apr 17, 2012
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,367
Hello Edaboard team,
I work on 16x8 LED matrix using MAX7219, and have problem with scrolling text on second matrix. Scrolling on first display is working.
I'm using PIC16F628A.
MAXX's are connected in cascade. DIN from first to DOUT second, CLK common, LOAD/CS common.
Here is code:
Thanks in advance.
Here is code:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 / Software SPI configuration sbit SoftSpi_SDI at RB3_bit; sbit SoftSpi_SDO at RB4_bit; sbit SoftSpi_CLK at RB5_bit; sbit SoftSpi_SDI_Direction at TRISB3_bit; sbit SoftSpi_SDO_Direction at TRISB4_bit; sbit SoftSpi_CLK_Direction at TRISB5_bit; // max7219 LOAD/CS(-) pin configuration// max7219 configuration void max7219_init1() { trisa=0; Chip_Select = 0; // SELECT MAX Soft_SPI_Write(0x09); // Disable BCD mode for digit decoding Soft_SPI_Write(0x00); Chip_Select = 1; // DESELECT MAX Chip_Select = 0; Soft_SPI_Write(0x0A); // Max segment luminosity intensity Soft_SPI_Write(0x0F); Chip_Select = 1; Chip_Select = 0; Soft_SPI_Write(0x0B); Soft_SPI_Write(0x07); // Display refresh Chip_Select = 1; Chip_Select = 0; Soft_SPI_Write(0x0C); Soft_SPI_Write(0x01); // Turn on the display Chip_Select = 1; Chip_Select = 0; Soft_SPI_Write(0x00); Soft_SPI_Write(0xFF); // No test Chip_Select = 1; } void max7219_init2() { Chip_Select = 0; // SELECT MAX Soft_SPI_Write(0x09); // BCD mode for digit decoding Soft_SPI_Write(0xFF); // using Code-B Soft_SPI_Write(0x00); // Bypass the 1st Chip Soft_SPI_Write(0x00); Chip_Select= 1; // DESELECT MAX Chip_Select= 0; // SELECT MAX Soft_SPI_Write(0x0A); Soft_SPI_Write(0x0F); // Segment luminosity intensity Soft_SPI_Write(0x00); // Bypass the 1st Chip Soft_SPI_Write(0x00); Chip_Select1 = 1; // DESELECT MAX Chip_Select1 = 0; // SELECT MAX Soft_SPI_Write(0x0B); Soft_SPI_Write(0x07); // Display refresh Soft_SPI_Write(0x00); // Bypass the 1st Chip Soft_SPI_Write(0x00); Chip_Select = 1; // DESELECT MAX Chip_Select= 0; // SELECT MAX Soft_SPI_Write(0x0C); Soft_SPI_Write(0x01); // Turn on the display Soft_SPI_Write(0x00); // Bypass the 1st Chip Soft_SPI_Write(0x00); Chip_Select = 1; // DESELECT MAX Chip_Select1 = 0; // SELECT MAX Soft_SPI_Write(0x00); Soft_SPI_Write(0xFF); // No test Soft_SPI_Write(0x00); // Bypass the 1st Chip Soft_SPI_Write(0x00); Chip_Select1 = 1; } //Send data function void Write_Byte(unsigned short myRow, unsigned short myValue) { Chip_Select = 0; // select max7219. Soft_SPI_Write(myRow); // send myRow value to max7219 (digit place). Soft_SPI_Write(myValue); Chip_Select = 1; // deselect max7219. } void Write_Byte1(unsigned short myRow, unsigned short myValue) { Chip_Select = 0; // select ma7219. Soft_SPI_Write(myRow); Soft_SPI_Write(myValue); Soft_SPI_Write(0x00); // Bypass the 1st Chip Soft_SPI_Write(0x00); Chip_Select = 1; } //Clear matrix function void Clear_Matrix(void) { unsigned short x; for(x=1;x<9;x++) { Write_Byte(x,0x00); } } unsigned int DisplayBuffer[]={0,0,0,0,0,0,0,0}; unsigned int DisplayBuffer1[]={0,0,0,0,0,0,0,0}; unsigned int speed=10; short i, l, k, ShiftAmount, scroll, temp,temp1, shift_step=1, StringLength; char message[]="MIPS LED MATRIX 2014" ; char index,index1; void main() { Chip_Select_Direction = 0; Soft_SPI_init(); max7219_init1(); max7219_init2(); Clear_Matrix(); StringLength = strlen(message) ; while(1) { for (k=0; k<StringLength; k++) { for (scroll=0; scroll<(8/shift_step); scroll++) { for (ShiftAmount=0; ShiftAmount<8; ShiftAmount++) { index = message[k]; index1=message[k-1]; temp =CharData[index-32][ShiftAmount]; temp1 =CharData[index-32][ShiftAmount]; DisplayBuffer[ShiftAmount] = (DisplayBuffer[ShiftAmount] << shift_step)| (temp >> ((8-shift_step)-scroll*shift_step)); DisplayBuffer1[ShiftAmount] = (DisplayBuffer1[ShiftAmount] << shift_step)| (temp1 >> ((8-shift_step)-scroll*shift_step)); } for(l=0; l<5;l++) { for (i=0; i<8; i++) { Write_Byte(i+1,DisplayBuffer[i]); //Scrolling k character on firt LED Matrix if(k>0) Write_Byte1(i+1,DisplayBuffer1[i]);Scrolling k-1 character on second LED Matrix } } } } } }
Thanks in advance.
