Programming Fails on Configuration
Question
Why does programming a device always fail on the Configuration Word(s), after which PICkit 2 won t
recognize the device?
Answer
This may be caused by a Configuration setting or program code that affects the ICSP PGD and PGC
pins. This interference can prevent the target PIC MCU from entering programming mode.
Check the menu option Tools>Use VPP First Program Entry when attempting a pro- gramming operation
on these devices. This program mode entry will usually get around the problem, but it requires that
the target device be powered from the PICkit 2 unit VDD
pin.
