16F877A EEPROM Write Problem. Help Please
shimanto
Bangladesh
bcf status,rp1
Please read the code and tell me where did I make the mistake. Or help me by writing a code for the EEPROM.
         list    p=16F877a
         include "P16F877a.inc"
         __CONFIG   0x3E79
         cblock 0x20
         count
         count1
         count2
         endc
         org 0x0005
         banksel TRISB
         clrf    TRISB
         banksel PORTB
         clrf    PORTB
         movlw 0xAA
         banksel EEDATA
         movwf EEDATA
         banksel EEADR
         movwf EEADR
         call wrt
         call read
         banksel PORTB
         movwf PORTB
wrt      bcf      INTCON,GIE
         bsf      STATUS,RP1
         bsf      STATUS,RP0
         bsf     EECON1,WREN
         movlw   0x55
         movwf   EECON2
         movlw   0xaa
         movwf   EECON2
         bsf     EECON1,WR
wait4write banksel PIR2
	 btfss     PIR2,EEIF
         goto      wait4write
	 banksel   EECON1
         bcf       EECON1,WREN
	 banksel PIR2
         bcf      PIR2,EEIF
         return
delay    movlw   .16
         movwf   count2
nn       movlw   .50
         movwf   count1
time1    movlw   .250
         movwf   count
         decfsz   count,f
         goto   $-1
         decfsz   count1,f
         goto   time1
         decfsz   count2,f
         goto   nn
         return
read     banksel EEADR
	 movwf   EEADR
         banksel EECON1
         bsf     EECON1,RD
         banksel EEDATA
         movf    EEDATA,w
         return
wp100
Advanced Member level 5
Prime Meridian
16f877a eeprom
Its a while since I coded that chip but the ORG 005 looks wrong to me, try ORG 000
Cannot see an obvious error, but its so easy to get a bank wrong or not to follow Microchips eeprom examples to the letter
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
eeprom-write
Several problems here:
1. you are correct to start your code at address 5 but to get there you need to put a "goto" at the reset address which is 0.
2. never use constructs like this:
bcf STATUS,RP1
bsf STATUS,RP0
clrf TRISB
use "banksel TRISB" instead. It makes it much easier to follow which register bank you are using. The banksel directive will generate the appropriate RP1 and RP0 settings for the register you name.
3. It makes it much easier to follow the code if you put labels on a line of their own too. For example your code:
delay movlw .16
movwf count2
nn movlw .50
movwf count1
time1 movlw .250
is far more readable as:
delay
   movlw .16
   movwf count2
nn
   movlw .50
   movwf count1
time1
   movlw .250
4. Never use code like "goto $-1". It isn't technically incorrect but it will cause you problems later in life, particularly if the jump is more than one address. Instead place a lablel where you want to jump to and then jump to the label. Doing that will let you insert extras instructions and edit the code without risk of the jump taking you to the wrong location.
Finally,
when posting code on this board, click the box with the word "Code" in it at the top of the entry box. At the end of the code, click it again to return to normal mode. It will prevent the board software removing tabs and formatting.
Brian.
shimanto
Bangladesh
banksel produces error when next to label
Thanks Brian.. I have made the necessary corrections that u told about the program. Still the EEPROM is not writing the data. I think its the wait4write loop, may be its becoming an infinite loop. Will anybody check and find the mistake for me plz.
Pommie
Newbie level 1
16f877a examples
I had a quick look at your code and the bit that stands out is EECON1,EEIF. EEIF is not in EECON1 but in INTCON. Try changing all EECON1,EEIF to INTCON,EEIF.
Mike.
betwixt
Super Moderator
Staff member
16f877a
Thanks for editing the code tags, it looks much more readable now.
I agree with Pommie, you are looking at the wrong bit to detect the end of the EE write sequence.
I would still advise you to make the other changes I suggested though. It will ultimately produce the same machine instructions but using 'banksel' makes the program far more readable and takes away the risk of setting the RP0 and RP1 bits wrongly.
For example, your code:
         movlw 0xAA
         bsf   STATUS,RP1
         bcf   STATUS,RP0
         movwf EEDATA
         bsf   STATUS,RP1
         bcf   STATUS,RP0
         movwf EEADR
can be rewritten as:
         movlw 0xAA
         banksel EEDATA
         movwf EEDATA
         movwf EEADR
Brian.
    shimanto
shimanto
Bangladesh
movlw 0x55 movwf eecon2 movlw 0xaa movwf eecon2
EEIF is in PIR2 register. I have corrected it and for selecting bank I have used banksel opcode. Its not working now... What should I do?
Kurenai_ryu
Advanced Member level 2
Bolivia
16f877a eeprom write
could you post your final code? also have you changed the bit? EEIF isn't in INTCON it's in PIE2 register!!! also, I would read the WR bit in EECON1 reg... as noted in the datasheet!!!! why didn't you used it???
shimanto
Bangladesh
16f877 eeprom write
@ Kurenai_ryu, I have already edited my post and wrote the final code. EEIF is in the PIR2 register, not in PIE2 register. I have used the WR bit in write sequece, I think u didnt see it. Any way it worked at last.
I have another problem, I have used the ADC of the 16F877A. I want to save the ADC outputs in EEPROM after a short delay. Can anyone give me the program code for this?
