130nm IBM Pex error in Cadence
moongang
Newbie level 1
New York, New York, United States
Hello there...
I am also facing PEX error message which is that
Error while compiling rules file /work/tools2/courses/ee6321/share/IBM_PDK/cmrf8sf/V1.8.0.0DM/Calibre/xRC/cmrf8sf_8LM_323_detailed.xrc.cal:
Error RES2 on line 70 of /work/tools2/courses/ee6321/share/IBM_PDK/cmrf8sf/V1.8.0.0DM/Calibre/xRC/cmrf8sf_8LM_323_detailed.xrc.cal - undefined layer name parameter: nsd.
Is there anyway to fix it?
I am facing the same issue with extraction using Calibre and IBM130nm. Is there a way to fix it? Any help is greatly appreciated.
Thanks!!
Thanks!!
Hi, I was wondering if you solved the problem, because I have the same problem at the moment.
I appreciate if you inform me.
Thanks,
Soa
