13.56MHz Generator connect via Matching network to Plasma chamber. Cable Length.
psdonald
Newbie level 1
Newbie level 1
Hello,
I have a 50ohm 13.MHz Generator.
I have a 50Hm input matching L network.
The Cable from the Generator to the network is 1 λ. (50ft 0.6VF)
Now the question.
The match cannot be connected very closely and has another output coax that I was told should be a 1/16λ length. (38.1" 0.7VF). Other sources say to make it as short as possible. The shortest i could make it would be 30". Should I go for 1/4λ after the match?
Should the output cable be included in the 1λ length and the input cable shortened by that amount.
Thanks
Peter
