Thota Suresh Avionics
Member level 2
- Joined
- Jul 15, 2013
- Messages
- 45
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 8
- Activity points
- 345
I am uisng 12Bit Pipeline ADC in PIC24FJ128GC006,
MPLAB V8.8 IDE,
C30 compiler.
by using sample code from PIC24F family datasheet i am not able get output,
and also from silicon errata of this family some errors regarding sampling,calibration for this
work around process also done and still i am not able to get the output ...
am i missing some thing ?
this is my code and to see the output i am using terminal programming,in terminal i am getting output voltage as 0 volts..
MPLAB V8.8 IDE,
C30 compiler.
include headers
volatile unsigned int channel_13;
volatile unsigned int channel_14;
int main()
uart_init(); // initialized uart for terminal program
ADC12_Init(); //12bit adc initialization
while(1)
IFS0bits.AD1IF = 0; //Clear the ADC1 Interrupt Flag
ADL0CONLbits.SAMP = 0;
while(IFS0bits.AD1IF==0 );
ADL0CONLbits.SAMP = 1; // Close the sample switch.
channel_13 = ADRES0; // Read result for the channel 13.
channel_14 = ADRES1; // Read result for the channel 14
printf("%f V \t" ,channel_13);
printf("%f V \n" ,channel_14);
void ADC12_Init(void)
TRISBbits.TRISB13 =1; //AN3 (RB13)
ANSBbits.ANSB13 =1;
TRISBbits.TRISB14 =1; //AN2 (RB14)
ANSBbits.ANSB14 =1;
ADCON1=0;
// ADCON2=0x0300;
ADCON3=0;
ADCON2bits.PVCFG = 0; // AVdd
ADCON2bits.NVCFG = 0; // AVss
ADCON3bits.ADRC = 1; // using FRC
ADCON3bits.ADCS = 8; // Tad
ADCON1bits.FORM = 0; // Output format is unsigned integer.
ADCON2bits.BUFORG = 1; // Result buffer is an indexed buffer.
ADCON2bits.BUFINT = 0; // No buffer interrupt.
ADCON1bits.PWRLVL = 0; // Low power, reduced frequency operation.
ADCON2bits.ADPWR = 3; // Module is always powered on.
ADL0CONL = 0;
ADL0CONH = 0;
ADL0CONLbits.SLSIZE = 2-1; // Sample list length: 2 channels.
ADL0CONHbits.ASEN = 1; // Enable auto-scan.
ADL0CONHbits.SLINT = 1; // Interrupt after auto-scan completion.
ADL0CONHbits.SAMC = 15; // Sample time is 15 TAD.
ADL0CONLbits.SLTSRC = 0; // Single trigger generated when SAMP is cleared.
ADL0PTR = 0; // Start from the first list entry.
ADL0CONHbits.CM = 0; // Disable threshold compare.
ADTBL0bits.ADCH = 13; //AN= Channel #13.
ADTBL1bits.ADCH = 14; //AN= Channel #14.
ADCON1bits.ADON = 1; // Enable A/D.
while(ADSTATHbits.ADREADY == 0);
ADL0CONLbits.SAMP = 1; // Close sample switch.
ADL0CONLbits.SLEN = 1; // Enable sample list.
printf("ADC12 Done\n");
