[SOLVED] 128 x 32 single port RAM VHDL code problem
chandlerbing65nm
Member level 5
I have a code and testbench for 128 x 32 single port RAM VHDL code, but the wave that I get is not correct. I am using a protected testbench created by my instructor. How should I change the code, I am on the learning process about RAM/ROM memories, so if you know something that I have to put in my code, please comment. Thanks
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.ALL;
ENTITY RAM128_32 IS
	PORT
		address	: IN STD_LOGIC_VECTOR (6 DOWNTO 0);
		clock		: IN STD_LOGIC  := '1';
		data		: IN STD_LOGIC_VECTOR (31 DOWNTO 0);
		wren		: IN STD_LOGIC ;
		q		: OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
END RAM128_32;
architecture syn_ram of RAM128_32 is
	type ram_type is array (127 downto 0) of std_logic_vector(31 downto 0);
	signal RAM : ram_type;
	signal read_a : std_logic_vector(6 downto 0);
	begin
		process(clock)
		begin
			if rising_edge(clock) then
				if (wren = '1') then
				RAM(to_integer(unsigned(address))) <= data;
				end if;
			read_a <= address;
			end if;
		end process;
	q <= RAM(to_integer(unsigned(read_a)));
	end syn_ram;
And this is the protected testbench:
--                            RAM Test Bench                                  --
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.numeric_bit_unsigned.all;
use ieee.std_logic_textio.all;
use std.textio.all;
use work.all;
-- Testbench entity declaration
entity AAC2M2P2_tb is
--  port( );
-- no external interface.....THIS IS THE TOP LEVEL
end AAC2M2P2_tb;
-- Testbench architecture body
architecture behavioral of AAC2M2P2_tb is
--- constant declarations
   constant delay:  TIME := 10 NS; -- defines the wait period.
   constant Points: integer := 10;   -- number of points this problem
                                    -- is worth
-- signal declarations
  signal clock_tb:  std_logic := '0'; --clock in
  signal address_tb:  std_logic_vector(6 downto 0);  -- address input
  signal data_tb:  std_logic_vector(31 downto 0);  -- data input
  signal wren_tb:  std_logic := '0'; -- write enable input
  signal q_tb:  std_logic_vector(31 downto 0);  -- output
  signal simend :std_logic :='0'; -- signal to end simulation, used to stop clock process
  signal ValidCheck: std_logic_vector(15 downto 0);
            -- unique to this problem, to check validity of submission
  type mem is array (integer range <>) of std_logic_vector(7 downto 0);
  signal ROM: mem(0 to 255);
-- component declarations before instantiation
-- Component declarations
Component RAM128_32  --
   port(
end component RAM128_32;
--- Procedures
  procedure Load_ROM(signal data_word : inout mem) is
     file ROMfile : text open read_mode is "vectorh.out";
     variable lbuf: line;
     variable i: integer :=0;
     variable fdata: std_logic_vector(7 downto 0);
   begin
     while not(endfile(ROMfile))  loop
     -- read digital data from input file
     readline(ROMfile, lbuf);
     hread(lbuf, fdata);
     data_word(i) <= fdata;
     i := i + 1;
     end loop;
  end procedure;
 procedure Write_ROM (signal data_word : inout mem) is
     file ROMfileOut : text open write_mode is "myvectorh.out";
     variable row: line;
     variable i : integer :=0;
     variable fdata: std_logic_vector (7 downto 0);
   begin
     while (i<256) loop
     fdata := data_word(i);
     hwrite(row, fdata, left,4);
     writeline(RomfileOut, row);
     i := i + 1;
     end loop;
  end procedure;
-- Top level output port assignments
begin
-- Component instances
-- RAM128_32
RAM_Test : RAM128_32 PORT MAP (
		address	 => address_tb,
		clock	 => clock_tb,
		data	 => data_tb,
		wren	 => wren_tb,
		q	 => q_tb
`protect BEGIN_PROTECTED
`protect version = 1
`protect encrypt_agent = "ModelSim", encrypt_agent_info = "10.4a"
`protect key_keyowner = "Mentor Graphics Corporation" , key_keyname = "MGC-VERIF-SIM-RSA-1" , key_method = "rsa"
`protect encoding = (enctype = "base64", line_length = 64, bytes = 128)
`protect KEY_BLOCK
UehJtsGpAgwkvvAgB2r6PVhqf9yMio9N2m7Upw/jCh6RhxIvg5tr9LwALPm/+Fbf
f48i6Krw65oeY39Q3TGnNG3gaefgFE73/N5CSolE0vTLJjmY9HHYN6QoocrMZgTR
rHn2PFZZzWTnlzRVRj9CGrNzqYrVEV8IDTTI7zonGlM=
`protect data_method = "aes128-cbc"
`protect encoding = (enctype = "base64", line_length = 64, bytes = 4196)
`protect DATA_BLOCK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`protect END_PROTECTED
end behavioral;
here's the waveform:
no idea. can you at least describe what you are expecting versus what you are getting?
ps: tell your instructor memories are not synthesisable, this is a very poor exercise.
The code looks like a template to infer FPGA block RAM. In so far it's well synthesizable.
Im not quite sure what you're talking about, Ive been infering rams using templates like this for 15+ years (since I started at UNI).
ThisIsNotSam is thinking ASIC designs not FPGA....FPGAs you can infer RAM. ASICs well that's why there are memory compilers.
correct. disregard my message... wrong forum.
The other point in post #2 is nevertheless true. We don't see which part of the wave is incorrect, we don't even know which part of the code has been created by you and what's the exercise specification.
To run the simulation, we would need the ROM image file vectorh.out.
