128/256QAM modulator/demodulator
goxy
Full Member level 4
Full Member level 4
I'm interested in 128 and 256QAM mod and dem for dataspeed 155Mb/s and above.
Does someone know available parts on net?
calvinhorng
Member level 4
Member level 4
I am also interested in this topic, if anyone can share, please PM me also.
Thanks in advanced
flatulent
Advanced Member level 6
Middle Earth
specialized
This is such a specialized modulation that such things are custom made and probably used only by cross counry microwave relay systems.
dainis
Re: specialized
Look Intersil ISL87060MIK and ISL87060DIK chips ...
Jackal
Member level 2
Member level 2
Russia, Krasnodar
Hi!
At this moment, we are work with microwave relay system.
And i tryd to find modulators/demodulators... nothing...
At this moment, we are use Altera's FPGA.
At www.altera.com you find Constallation Mapper/Demapper Megacore.
That help you to create modulator/demodulator.
Regards, Jackal.
redsk_y
Member level 4
Member level 4
italy
The most important part for this kind of modulation is the equalization
structure of the receiver.
Furthermore, must be taken in count the phase noise of the LOs and linearity of PA.
Best regards,
Wacko2000
Junior Member level 3
outer space
QAM mod/demod chips for 155 Mb do not exist at this moment as far as I know.
This would in practice require a very high constellation like 1024 QAM, which you do not like to have.. Needs very good transmission medium and low phase noise.
I think you have more luck in the range of WLAN OFDM chipsets although 155 Mb is a lot...
Wacko2000
outer space
Btw... you can play with those 'plug and play' IP blocks from Altera but those are not efficient with respect to hardware needs.
Furthermore.. 155Mb QAM ? Well.. good luck with your FPGA's...
dainis
Look Intersil site for Broadband wireless modems, modulation up to 128QAM, speed up to 238 Mbps:
h**p://w*w.intersil.com/data/an/an9969.pdf
h**p://w*w.intersil.com/data/an/an9934.pdf
At this time this is more integrated solution for high speed wireless modems .....
