I don't know the transformer configuration nor the voltage waveform.
I assume you should adjust your winding ratio for the lowest input voltage and the highest output voltage.
Why 50 Hz switching? Double the frequency and you will need about half the size of the transformer.
( your transformer is about 150kg, isn't it?)
Full wave rectifier with 120A... I expect at least 2V voltage drop, this makes at least 250W of power dissipation. A lot of heat..
Decide synchronous rectifying.
Klaus
