12 bit ADC over USB at 10 kHz
itisme
Hello,
I'm trying sample one channel ADC at 10kHz and transmit the data over USB serial. The code (CCS C) is below.
Unfortunately USB halt after transmitting several tens of samples. I think the problem with the speed of "printf(usb_cdc_putc,...)", but have no idea how to solve it.
I'll appreciate for help.
#include <18F2553.h>
#device ADC = 12
//configure a 20MHz crystal to operate at 48MHz
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
//#use rs232(baud = 115200, xmit = PIN_C6, rcv = PIN_C7)
#include <usb_cdc.h>
//#include <input.c>
//#include <stdlib.h>
unsigned int16 adc_data;
int32 i=0;
int8 s2r=1; //s2r - Seconds to record
int32 c2t; //c2r - Cycles to transmit
//Initializing the RTOS Program
#use rtos(timer = 0, minor_cycle = 10us)
#task(rate = 100us, max = 10us) // 100uS -> 10kHz
void transmit_over_usb()
        //adc_data = read_adc();
        printf(usb_cdc_putc, "%Lu\n\r", read_adc());
        if(++i==10000)//(i == c2t)
            rtos_terminate( );
void main()
   #use standard_io(A)
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_64); // for 48MHz OSC
   //setup_adc(ADC_CLOCK_DIV_16); // For 20 MHz OSC
   set_adc_channel(0);
   delay_us(10);
   usb_cdc_init();
   usb_init();
   while(!usb_cdc_connected()) {}
   do
      usb_task();
      if (usb_enumerated())
         wait_usb: // Label
         while (usb_cdc_getc() != 'r') ;
         i=0;
         s2r=1;
         c2t = (s2r*1e6)/250; // How many cycles to transmit the data. NOTE: Denumerator should be equal to "rate" in main RTOS task
         output_high(PIN_B0);
         rtos_run();
         output_low(PIN_B0);
         // printf("Done!\n\r");
         printf(usb_cdc_putc,"5002\n\r");
         goto wait_usb;
   } while (TRUE);
hi itisme.....
I dont know to write a smplie line of code
can you help me to write a programme?
Please check my new thread...........please
