[PIC] 10 bit result of ADC is require to convert in decimal to display in LCD
ecaits
Member level 4
Member level 4
I am using 16F877 pic controller.
I have prepared code for ADC.
Analog input is converted in to ADC result. Now I want to convert that hex number to decimal to display in lcd.
Plz support how can i convert hex to decimal for ADC 10 bit output???
Your ADC result needs to be converted to ASCII format to be displayed on a lcd.
However, how you do that is depends on the compiler you are using, which is ...?
use following code to write on lcd or u can send it to UART
void show_decimal(unsigned int numb)
	unsigned int temp;
	temp = numb/10000000;			  //1
	data_write(temp + '0');
	temp = (numb/1000000)%10;		//2
	temp = ((numb/100000)%100)%10;	   //3
	temp = (((numb/10000)%1000)%100)%10;
	temp = ((((numb/1000)%10000)%1000)%100)%10;
	temp = (((((numb/100)%100000)%10000)%1000)%100)%10;
	temp = ((((((numb/10)%1000000)%100000)%10000)%1000)%100)%10;
	temp = (((((((numb/1)%10000000)%1000000)%100000)%10000)%1000)%100)%10;
first it gives MSB then towards LSB.
hello,
i suspect a probleme, even i didn't try your code... for the first 3 items..
because you will allways get 0 as result with using unsigned int for variable Temp.
(Divider is over range > 65535 !)
i propose this code , C18 MPLAB
use a long int as intermediate calculus , and a flag to push "0" or "space" to get a constant width of char
and another flag to print out on USART or LCD
#define OUT_RS232 Drapeaux.Lcd=0;
#define OUT_LCD Drapeaux.Lcd=1;
unsigned char Entree[17]="1234567890123456";
unsigned char *valtxt;
 struct chbits {   // 8 flags
                 unsigned FrameErr:1;
                 unsigned Over:1;
                 unsigned Elligible:1;
                 unsigned Togle:1;
                 unsigned Blc:1;
                 unsigned standby:1;
                 unsigned Fill:1;
                 unsigned Lcd:1;
               }Drapeaux ;
 union
{  unsigned char Fanion;
   struct chbits Drapeaux ;
} Flags;
void Write_Word_(unsigned int M,char Sign)
unsigned int i,k,l;
unsigned long M1;
 valtxt=&Entree[0];
 if (Sign>1) return;
 if (Sign==0)
  {       M1=M;
        ultoa(M1,&Entree[0]);
  else itoa(M,&Entree[0]);
 if (Flags.Drapeaux.Fill)
  k=strlen(Entree);
  for (i=0;i<k;i++) Entree[4+Sign-i]=Entree[k-i-1];
  for (i=0;i<(5+Sign-k);i++)
  {if (Flags.Drapeaux.Blc) Entree[i]='0'; else Entree[i]=' ';}
 Entree[5+Sign]=0;
 #ifdef LCD2x16
 if (Flags.Drapeaux.Lcd==1) LCD_PutRamString(valtxt); else k=PutStr_RS(valtxt);
 #else
 #endif
In this case, First i will get ADC output in 10bit and will stored in register ADRESH and ADRESL and this output is in hex form.
Now I need to convert this 10 bit hex code in one decimal number.
After getting one decimal number I have to use that division and modulo operation.
My question is, i will get direct one decimal number or i need to convert 10 bit hex code into one decimal number???
hello,
Inside every MCU , value are always in binary mode .. 0 or 1
so when you get the result of ADC
You get a binary value...from the 2 register of 8 bits ...
and combine them into a register of 16 bits
but only 10 bits are significatif, so
after a Right alignment , you can use this 16 bits register wich can contain a binary value from
0000000000000000 to 0000001111111111
after you can use or represente it for displaing
as an hexadecimal value with 4 digits
0000 to 03FF
or decimal value with 5 digits
0000 to 1023
on evoluate PIC18F in C18 langage it is easy to use differnet mode for displayng the value
example
M=read(ADC);
//we suppose result of reading ADC is in the integer value M = 512
 k=fprintf(_H_USART," M=%04u      M=%4X ", M,M);
will print on terminal RS232 (via UART)
M=0512 M=0200
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
unsigned char digits[5];
unsigned int adcval;
void main(){
    while(1){
        digits[0] = adcval / 1000 + 48;
        digits[1] = (adcval / 100) % 10 + 48;
        digits[2] = (adcval / 10) % 10 + 48;
        digits[3] = adcval % 10 + 48;
        digits[4] = '\0';
        lcd_string(digits);
Reactions: ecaits
    ecaits
Here, do I need to convert 10 bit ADC result to Decimal value??? Or can i directly assign 10 bit ADC result to variable "adcval" and use above division-modulo operation???
by doing so you are doing same thing to convert it to decimal and then need to convert to ASCII
