Hi Can anyone help me i have a 1 volt signal from an i/o card and i need to control a relay
i have been told i need lots of different things to get this to work can someone tell me what i need
i done electronics 20 years ago but i am far from up to speed
Dear Friend
Hi
Do you want control a relay with one volt? it is simple , use a simple BJT transistor , that your relay is in it's collector , and use a anti parallel diode , in parallel with your relay at reverse bias . and the emitter should be grounded . and your one volt with a resistor will be connect to the base.
Best Lucks
Goldsmith
connect 1k resistor to i/o and the other end to transistor base,you may use the transistor like c945 or c1383,apply -ive to emitter and +ive through relay coil to collector and place a diode across the coil to avoide the back emf as goldsmith told you ealier,yours relay will operate provided you apply the dc voltage to the relay as per manufacturer instructios.
