tetooo
Newbie level 3
Hi all,
I am tried to write VHDL code for 1 to 8 Demux and that's what i finish with it
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
ENTITY Dmux1to8 IS
PORT ( X : IN STD_LOGIC;
S : IN STD_LOGIC_VECTOR(0 TO 2);
En : IN STD_LOGIC;
W : OUT STD_LOGIC_VECTOR(0 TO 7));
END Dmux1to2;
ARCHITECTURE Structure OF Dmux1to8 IS
SIGNAL m : STD_LOGIC_VECTOR(0 TO 5);
BEGIN
G1: FOR i IN 0 TO 1 GENERATE
Dec_ri: Demux1to2 PORT MAP ( m(i), S(0), X);
G2: FOR i IN 2 TO 5 GENERATE
Dec_left: Demux1to2 PORT MAP ( m(i), S(1));
END GENERATE ;
END GENERATE ;
Demux5: Demux1 to 8 PORT MAP ( m(2),m(3),m(4),m(5), S(2), W(0 TO
7) );
END Structure;
can any one told me if is it right or not?
if there are any mistakes can you help me to correct it ?
LIBRARY IEEE;
ENTITY Dmux1to8 IS
En : IN STD_LOGIC;
END Dmux1to2;
BEGIN
END GENERATE ;
END GENERATE ;
7) );
END Structure;
