1 second Interrupt from 8051?
hi here is subroutine for cal. of 1 sec delay
HUNDERED EQU 100
COUNT EQU -10000 ;100*10000 US=1SEC
DELAY: MOV R7,#HUNDERED
AGAIN: MOV TH0,#HIGH COUNT
MOV TL0,LOW COUNT
SETB TR0
WAIT2: JNB TF0,$
CLR TF0
CLR TR0
DJNZ R7,AGAIN
RET
END
The clock used is a 12MHz .
This subroutine is for 1 sec delay
HUNDERED EQU 100
MOV TL0,LOW COUNT
SETB TR0
WAIT2: JNB TF0,$
CLR TF0
CLR TR0
DJNZ R7,AGAIN
RET
END
Sorry for the interrupt guys, but.... the last two solutions provided for this problem look alike eachother veeeerry much...
Is someone in need for points?
Hi all
I notice that no one has asked - what the required timing tolerance on the 1 Second interval?
Does the micro have to action a port pin within ±1µs of 'real time' then this is a will place various constraints on the method used.
If tolerance is ±50ms constraints are more relaxed. If it is a display update this will be different again.
Clarification of the timing requirement might help in the solution.
regards ... Polymath
