asd913 said:I've already built a couple projects where I made use of the I2C bus to communicate between two PICs.
to ensure that both PICs don't access the LCD at the same time
bbarney said:i have 2 seperate pic projects i want to connect to one lcd in the same box.is there any way to connect them using some kind of switching
arrangement that is fairly simple or even using a 3rd pic,i have lots of pic's but not to good at writing the code.
any suggestions?
nenad_p said:bbarney said:i have 2 seperate pic projects i want to connect to one lcd in the same box.is there any way to connect them using some kind of switching
any suggestions?
You can use digital multiplexer such as
74hc175 (quad 2 imput mux) so you can multiplex all
data and control lines from controlers to display
