per_lube
Hi all,
I got a down-converted signal from an RF front-end and the frequency of the down-converted signal varies from 1 kHz -100 MHz.
I need to know the frequency of the down-converted signal and take some decisions based on the frequency in an electronic circuit.
I found some frequency-to-voltage converter chips (such as LM2917) which works only up to 500 kHz - 1 MHz.
I can use this one to measure up to 1 MHz, but I need to measure frequencies up to 100 MHz.
I don't need a very accurate frequency measurement.
Could anyone suggest a method to perform this?
cheers,
per_lube
cheers,
per_lube
