I would sincerely appreciate if someone can help me locate a SMD / CHIP LED in Package Size 0805 which is bi-directional / anti parallel /
Basically, the package should have 2 LEDS of the same color in anti parallel connection. So no matter how you connect the polarity of input 1 led will glow.
My constraint is size i need the LED in size 2.00mm*1.25mm*0.70mm Max.
If anyone could kindly help me locate a source / online or offline for this or share a datasheet it would be great.
Thanks
Anurag
