tonyctsiu
Member level 1
I have to design a circuit to convert the signal picked up by an inductor coil. The signal to be picked up is generated by strobe. The voltage generated by the inductor peak at some where ranges from 0.3V - 5V when viewed in my oscilloscope
y
Now the problem is that I need to convert the pulse into a logical one which is fed into a logic pin of MCU, which is at least 70% of the Vdd.
Some other requirement:
The battery CR2032 must operate this circuit for 3 years during idle.
The delay of the MCU receiving the logic 1 must be less than 1 us.
I an struggling between using MOSFET or opamp. For the opamp option the low power opamp does not have enough slew rate for the mcu to detect the local 1 fast enough. So it seems that MOSFET is the only option.
For MOSFET. is there any (very) low power consumption design which can convert 0.3-5 V into logical 1 very quickly?
Thank you
Tony Chun Tung Siu
y
Thank you
Tony Chun Tung Siu
