Schematic Level and Block level implementation of Divide by 3 circuit.
shaikhsarfraz
Full Member level 5
Can any body forward me the Schematic Level or Block level implementation of Divide - by - 3 circuit.
I need this block for the design of Frequency Synthesiszer.
Regards
Shaikh Sarfraz
Re: Divide by 3 Circuit
try this
this is working::::
I am not able to view the site.
Can you send it through an attachment in EDA Board.
Its urgent
Thanks and Regards
Sarfraz
I think it will be easier and judicial to implement a digital logic using flip flops rather then using analog blocks.
Any inputs from anybody ?
Regards
Sarfraz
Yes.
However, you've posted to the Analog Circuit Design and none of your previous posts said "digital". You'll get a better and quicker answer in the digital section of the EDAboard.
Divide by 3 Circuit
shaikhsarfraz
you can design divide3 using 2 flip-flops.
You deed at least 3 flip-flops if you want to 50%duty cycle.
I am designing a frequency systhesizer.
This block has a divide by 3 (frequency divider) block.
I need a circuit with 50 % duty cycle.
Currently I am desiginig the other blocks.
So if some body can direclty give me some inputs on this issue it will be beneficial for me, as it will reduce the time for the project.
regards
sarfraz
You can try CD4017 to make a divide by 3 counter, and then use CD4013 to make the pulse 50% duty.
nguyennam
hi Shaikhsarfraz,
This should work . . .
According to my simulator. :D
on1aag.
on1aag..
Did u designed it or copied from certain place else?
if the first, how could u? From FSM or what?
Regards,
Ahmad,
this method use the control logic on clock path. I think it is not good for ASIC design. Is it there any other method to avoid logic on clock path?
thanks
maybe you can try this. I used it for divide by 3 and worked pretty well
u can use crystal oscillator wid a harmonic generator (as found in communication transmitters)
may i ask what's the frequency range it works at ? and how much current it draws.
i also used this architecture to realize a divider by 3, passed full corner simulation in a 0.18um CMOS process. but the current consumption is 6~10mA (it changes due to reference current is generated by internal resistor ) which is not acceptable。
so i am considering to change a method to realize divide by 3, first by 1.5, then by 2.
but not done yet, any idea?
