venkates2218
Full Member level 6
Please refer the circuit diagram.
I have to sense the GND from float sensor for my operation.The project will have 8 sensors so i'm used 74HC4051 to reduce the usage of pin in the micro controller(PIC16F877A).
When I switched ON the circuit i'm always getting the output in high state from the multiplexer.
The output not depending on the S0,S1,S2.It working abnormally.
How to sense the GND from the sensor by using multiplexer IC and what changes have to make in the circuit to work perfectly.
