Harmonic distrosion reduction dsp algorithms
garimella
Full Member level 5
I captured live signal is oscilloscope and imported to matlab for analysis(sampled at 50e-06). I found that the signal carries lot of noise and has 2% THD. Now is there any solution or DSP algorithm to nullify THD and noise together?
THD of a pure sinewave?
Or is it a mix of several frequencies?
How do you measure it?
If via FFT, then mask out all unwanted signals (frequencies) and perform an inverse FFT.
Klaus
Hi
I am attaching the image captured from Matlab. Basically I wanted computationally efficient method to remove harmonics, reduce THD to get a clean wrinkle free wave.
