Aussie Susan
(Possibly off topic)
Dan1138 - MPLAB is the IDE only; you really need to look at the compiler that did the actual work which was probably an old version of C18. MPASM typically codes as part of the compiler package (IIRC)
Using a supported compiler (XC8) and IDE (MPLABx) would be the way to go now.
Susan (being a bit picky!)
