Convert 0 to 10 volts into from 5 to 0 volts
Medtronic
Full Member level 5
Egypt
Convert 0 to 10 volt into from 5 to 0 volt
Dear all my friends
i have an input volt from 0 to 10 volt ... i need to change it to 0 to 5 V with reverse action ... means i need when input is 10 the out is 0 and when input is 0 the out is 5 v
how can i get this
Thanks in advance
MedTronic
Re: Convert 0 to 10 volt into from 5 to 0 volt
your requirement does not specify whether you want linear response (i/p 0 to 10v and o/p 5 to 0v with inbetween ranges)
or for only extremes.( with 10v i/p 0v o/p and 0v i/p 5v o/p.)
I read it as inverting amplifier specification, G = -0.5, +10V output offset.
Simple inverting OP circuit, R1 = 2*R2, n.i. input biased with 3.3V reference voltage.
I need a linear response ... for Fvm please give schematic ... thanks very much
Is it asking too much to google for "inverting amplifier circuit" on your own?
You will find many thousands of hits. Almost all describe the same.
Many of them have detailed description about operation and part value calculation.
Klaus
Here you have it with the explanation: https://payhip.com/b/5Srt
Below is the LTspice simulation of the inverter circuit with the required offset to give 5V to 0V from a 0V to 10V input with a single 5V supply voltage.
For other supply voltages, the ratio of R2 and R4 will need to be changed.
If high accuracy is needed then the voltage to R2 should be from a voltage reference.
I apologize for my post above. I forgot to check the preview of the e-book. The inverting configuration is not in the preview, but in the paid version. Here you have free materials about the inverting configuration that should help you to understand this configuration:
- https://www.youtube.com/watch?v=U1KbM4ffiLg
- https://slideplayer.com/slide/3331407/ s.20
- https://slideplayer.com/slide/6231746/ s.28-29
- https://slideplayer.com/slide/3187860/ start at 1:40
Hope that will help.
