When creating a circuit inside Proteus, how do I configure fuse bits?
jfminformatica
Junior Member level 3
I'm working with Proteus 8 and sometimes I get a circuit already created on the internet that uses PIC, it's necessary to configure the fusebits to work perfectly. How do I do ?
Double click the microcontroller in the sheet, and you'll se some fuse options.
To perform the simulation, you need the .hex or .asm file for the specific PIC. You can configure the path under the part setup.
