tayyab786
Junior Member level 3
I am trying to generate a desired random number in range.
for random number we use LFSR alogorithm. Now I want...First time LFSR output become the min number . Now in next cycle the random number should greater than previous LFSR number and so on, but it also not exceed with max value. max value is the max number which can be generate by LFSR(depend on the number of bits using in LFSR e.g 8 bit LFSR generate 255 max value)
I know some method e.g
min+LFSR draw back : it can exceed max value which is not desired
fixed some bits in LFSR with min value draw back: 1.not lie in desired range 2.e.g max value is 8 and previous LFSR output is 6...Now in 8 bit how to
fixed min value as well as LFSR output?
Can any one suggest solution that would be applied in verilog language
