8051 Microcontroller Switches to Control 2 Leds
vead
Full Member level 5
india
switches to control 2 leds
Hello everyone
I want each switch to control its own led, so switch1 control red led and switch 2 control green led . 8051 and keil compiler
1. Does this program control two led's ?
2. Is it efficient program or it can be better ?
#include<REGX51.h>
  #define led_off          0
  #define led_on           1
  #define Switch_off       0
  #define Switch_on        1
 /*set two Switches*/
  sbit  Switch1 = P1^1;
  sbit  Switch2 = P1^2;
  /*set to LEDs*/
  sbit red_led = P2^1;
  sbit green_led = P1^2;
  /* Delay time  */
  void delay (unsigned long wait)
       unsigned int i;
       for (i = 0; i < wait;  i++);
 void initialize (void)
      red_led = led_off;
      green_led = led_off;
      Switch1 = Switch_off;
      Switch2 =Switch_off;
  void main (void)
     initialize ();
while (1)
        while (Switch1 == Switch_on)
		  red_led= led_on;
		  delay (1000);
	          red_led = led_off;
    while (Switch2== Switch_on)
	       green_led = led_on;
	       delay (1000);
No, the LED will be Off for just few microseconds (or rather, some instructions of the microcontroller) unless you add an extra delay. Anyway, you might start thinking about using some simulator or doing protoboard experiments. It is not good practice to expect others to confirm the supposed operation of your code. No one has the dexterity of a compiler, and everyone can fall into the same mistake, anyway you were already made aware of that in other threads.
green_led = led_on;
delay (1000);
delay (1000);
Yes, by using timer interrupt to achieve the delay without blocking the CPU; take a look on examples for the compiler you are using.
Reactions: vead
    vead
... or at least a sheet of paper and a pencil.
Klaus
Reactions: vead
    vead
I'm missing a description of intended program function. In so far it's impossible to answer the question.
The delay purpose isn't obvious. Presently it's acting as off-delay.
If both switches are activated simultaneously, the second one will be ignored. Is this what you want?
Reactions: vead
    vead
I have tested below code in simulator. Both switch are working
#include<REGX51.h>
  #define led_off          0
  #define led_on           1
  #define Switch_on        1
  sbit  Switch1 = P0^5;
  sbit  Switch2 = P3^1;
  /*set to LEDs*/
  sbit red_led = P1^0;
  sbit green_led = P1^1;
  /* Delay time  */
       unsigned int i;
      red_led  =  led_off;
      Switch2 =  Switch_off;
  void main (void)
     initialize ();
while (1)
        if (Switch1  ==  Switch_on)
		 red_led =  led_on;
		 delay (2000);
	         red_led =  led_off;
		 delay (2000);
        if  (Switch2== Switch_on)
	          green_led  =  led_on;
	          delay (4000);
                   delay (4000);
what do you think about code? Do you find any mistake? How to write better code that should be much faster and able to check all test?
the simulator will give reliable results.
I wonder if you recognized the behaviour:
* the duty cycle of the red LED is different to the green LED.
* there is no defined LED state when you switch OFF (your switches).corrected: sorry. The LEDs are OFF.
Klaus
...and the LED duty cycle influence each other.
means: that the brightness of a LED is different when the other switch is ON or OFF.
Klaus
Klaus
Please look at following screen shot
* impossible to validate brightness or duty cycle
* impossible to see the fourth state (important) when both switches are ON.
Klaus
Klaus
Sorry what do you mean by britness. I just removed delay in while loop to show condition when both switches are ON
See another image where you can see red and green LED.
brightness of a LED. I think this is well defined.
If just the red LED is ON:
The red LED duty cycle is 2000/2000 (ON/OFF)
If both LEDs are ON:
The red LED duty cycle is 2000/10000 (ON/OFF)
Klaus
Reactions: vead
    vead
Klaus
How to replace switch with push button ?
I want to have a LED turn on when I push a button and go off when I push the button a second time.
Does this read the status of push button ?
      if (Switch ==  switch_pressed)
                 debounce (40 );   // 40 ms
