which substrate is best for design high freq microstrip line
kent616
Junior Member level 1
is it higher Er or lowe Er
Re: which substrate is best for design high freq microstrip
The tradeoff is that low er usually has lower losses but the circuits are larger.
    kent616
Generally, the loss is a sum of 2 contributes, namely conductor loss and dielectric loss. Usually the 1st il larger than the latter.
Using low er dilectric, the metal is geometrically larger, so less lossy.
But conductor loss is dependent on dimensions, conductivity and roughness.
Whit hard substrates (lile Alumina, Quartz, etc) it's possible get lowest roughness.
Unfotunately hard substrate have high er.
So for microwave frequencies there is no big difference, for millimetric frequencies the best materials are low er or low roughness materials, but not flexible PCB (like Rogers 6010) because it's higher roughness.
    kent616
Alumina 96% Al2O3 is very good for your application
    kent616
