sabersimon
Newbie level 2
Hello,
Thanks in advance. I am kinda new to VHDL. Anyway, I am having an issue where I am getting this error within questa sim.
The function in question is:
I am implementing it in my code where it looks like this:
Both ' signed(sign_x_pi_din) * cordic_cossin_oX and ffxp_correction_func_v_r" are signed values and the correct bitwidths are being used. Any help would be great. Also, I have included the package where the function is present within my module.
Thanks
###### /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(312): lb_ref_func_v_r <= f_multR(signed(sign_x_pi_din) * cordic_cossin_oX, ffxp_correction_func_v_r, CAL_RRF_WL, CAL_RRF_FL, CAL_ANGLES_WL, CAL_ANGLES_FL);
# ** Error: /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(312): No feasible entries for subprogram "f_multR".
###### /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(313): lb_ref_func_v_i <= ffxp_Pxg.f_multR(signed(sign_x_pi_din) * cordic_cossin_oY, ffxp_correction_func_v_i, CAL_ANGLES_WL, CAL_ANGLES_FL, CAL_RRF_WL, CAL_RRF_FL);
# ** Error: /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(313): (vcom-1136) Unknown identifier "ffxp_Pxg".
###### /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(317): lb_ref_func_h_r <= f_multR(signed(sign_x_pi_din) * cordic_cossin_oX, ffxp_correction_func_h_r, CAL_ANGLES_WL, CAL_ANGLES_FL, CAL_RRF_WL, CAL_RRF_FL);
# ** Error: /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(317): No feasible entries for subprogram "f_multR".
###### /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(318): lb_ref_func_h_i <= f_multR(signed(sign_x_pi_din) * cordic_cossin_oY, ffxp_correction_func_h_i, CAL_ANGLES_WL, CAL_ANGLES_FL, CAL_RRF_WL, CAL_RRF_FL);
# ** Error: /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(318): No feasible entries for subprogram "f_multR".
###### /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(347): end architecture ; -- mixed
# ** Error: /home/nbrummel/Documents/SWOT/cal/cal/cal_loopback_ref_func_dir/src/loopback_ref_func.vhd(347): VHDL Compiler exiting
-- multiplication with requantization of the output
function f_multR(A, B:unsigned;
AfxWL, AfxFL, BfxWL, BfxFL,
CfxWL, CfxFL:natural) return unsigned;
function f_multR(A, B:signed;
CfxWL, CfxFL:natural) return signed;
-- versions which assume all inputs and outputs have the same widths
function f_multR(A, B:unsigned; fxWL, fxFL:natural) return unsigned;
function f_multR(A, B:signed; fxWL, fxFL:natural) return signed;
CfxWL, CfxFL:natural) return unsigned is
constant CSCL : integer := AfxFL+BfxFL-CfxFL;
variable prod : unsigned(AfxWL+BfxWL-1 downto 0);
begin
-- Synplify creates a mess if the multiplier cannot
-- fit into 4 DSP48s. That is, for an unsigned multiply,
-- one of the inputs must less than 35 bits, and both
-- must less than 49 bits
assert AfxWL < 35 or BfxWL < 35 report "Need to use fw_multR (35)" severity warning;
assert AfxWL < 49 and BfxWL < 49 report "Need to use fw_multR (49)" severity warning;
prod := A * B;
if CSCL < 0 or CSCL+CfxWL > AfxWL+BfxWL then
return f_requant(prod, AfxWL+BfxWL, AfxFL+BfxFL, CfxWL, CfxFL);
else
return prod(CfxWL+CSCL-1 downto CSCL);
end if;
end function f_multR;
CfxWL, CfxFL:natural) return signed is
variable CSCL : integer := AfxFL+BfxFL-CfxFL;
variable prod : signed(AfxWL+BfxWL-1 downto 0);
begin
-- fit into 4 DSP48s. That is, for a signed multiply,
-- one of the inputs must less than 36 bits, and both
-- must less than 50 bits
assert AfxWL < 36 or BfxWL < 36 report "Need to use fw_multR (36)" severity warning;
assert AfxWL < 50 and BfxWL < 50 report "Need to use fw_multR (50)" severity warning;
prod := A * B;
-- need to return bits outside the range of prod
else
-- this will not necessarily return a result with the same
-- sign as prod, if we are losing MSBs with data, but it
-- matches the logic in f_requant.m
end if;
-- Versions where inputs and outputs have the same size
function f_multR(A, B:unsigned; fxWL, fxFL:natural) return unsigned is
constant CSCL : integer := fxFL;
variable prod : unsigned(2*fxWL-1 downto 0);
begin
assert fxWL < 35 report "Need to use fw_multR (35)" severity warning;
prod := A * B;
return prod(fxWL+CSCL-1 downto CSCL); -- that is, (2*fxWL-1 downto fxWL)
function f_multR(A, B:signed; fxWL, fxFL:natural) return signed is
variable prod : signed(2*fxWL-1 downto 0);
begin
assert fxWL < 36 report "Need to use fw_multR (36)" severity warning;
prod := A * B;
Thanks
