libraries in modelsim in vhdl
Junior Member level 2
i have used the following libaries
LIBRARY IEEE;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.numeric_std.all;
still the error in modelsim shows :
** Error: G:/vhdl code/vhdl code/dwt_main.vhd(30): (vcom-1078) Identifier "UNSIGNED" is not directly visible.
Potentially visible declarations are:
ieee.NUMERIC_STD.UNSIGNED (subtype declaration)
ieee.std_logic_arith.UNSIGNED (type declaration)
** Error: G:/vhdl code/vhdl code/dwt_main.vhd(31): (vcom-1078) Identifier "SIGNED" is not directly visible.
ieee.NUMERIC_STD.SIGNED (subtype declaration)
ieee.std_logic_arith.SIGNED (type declaration)
how to solve it
The error is caused by using two conflicting numeric libraries together. If you are using ieee.numeric_std, you can't use ieee.std_logic_arith.
You can use them, as you can directly assign whichever you want. eg:
signal a : numeric_std.unsigned;
signal b : std_logic_arith.unsigned;
Meaning you can now use both libraries in the same file. But why bother? just delete the non-standard std_logic_arith library and your life is made easier.
numeric_std and std_logic_arith are standart for Modelsim,but it have to right way in using only one of them.
Actually this should be... Modelsim includes both libraries, the IEEE library numeric_std and the Synopsys library std_logic_arith. Only numeric_std is part of the official language.
