kela3kela
Full Member level 4
Good Day Member,
I am working on a rectenna that harvest GSM energy at 900 MHz and converts it into DC Voltage for charging a cell phone battery. From various literature review, I have made a simple patch antenna in CST MWS and designed its relevant rectifier circuit in ADS. The questions I want to ask are following:
1. In most of the rectenna papers, the output results are mentioned in terms of DC Voltage but not current.Why is that? As we all know that Voltage is derived quantity, it is the actual current that charges the device.So why not discuss results on the basis of current rather than voltages?
2.With regards to any cell phone battery values i.e. Voltage=3.8 V, Current 3200mAh and Power 9.88Wh [hypothetical]. Should I design my circuit that meets these requirements or just DC output from rectifier in terms of Voltage would suffice as much of literature demonstrates?? Mostly batteries are represented with mAh values, so should I concentrate my result on current??
3.Is multiband RF rectenna realizable as I haven't seen any papers that were successful in doing so?
Awaiting your kind replies,
