Hellsong
Newbie level 3
I need help with the programation of and elevator, I'm traying to make a program to control a stepper-motor in order to make an elevator of 4 floors.
it works by pushing the button of the floor, and making a sequence to control the stepper-motor to make the elevator move to the floor it was required, and using proximity sensors to know where is the elevator, when the elevator is in front of one sensor, the output of the sensor is "0", it has 5 sensors for the 4 floors. here is the syntax of my program
the problem I'm having is that, when I try to compile it, it shows these errors
if you could help me, I would be very glad, thanks and I'm waiting for you'r answers.
Also you should know that I'm traying to program this into a GAL22V10D
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity Elevador is port( p1,p2,p3,p4,s1,s2,s3,s4,s5 :IN BIT; q :OUT INTEGER RANGE 0 TO 7; csal :OUT BIT_VECTOR (3 downto 0)); end Elevador; architecture Elevador of Elevador is begin piso1:PROCESS (p1) VARIABLE conteo :INTEGER RANGE 0 TO 7; BEGIN IF (p1'EVENT AND p1 ='1') THEN IF (s1='0' AND s2='0') THEN conteo := 0; ELSE conteo := conteo -1; END IF; q <= conteo; END IF; --PASO COMPLET0 CASE conteo IS WHEN 0 => csal <= "1010"; WHEN 1 => csal <= "1001"; WHEN 2 => csal <= "0101"; WHEN 3 => csal <= "0110"; WHEN 4 => csal <= "1010"; WHEN 5 => csal <= "1001"; WHEN 6 => csal <= "0101"; WHEN 7 => csal <= "0110"; END CASE; END PROCESS piso1; piso2:PROCESS (p2) VARIABLE conteo :INTEGER RANGE 0 TO 7; BEGIN IF (p2'EVENT AND p2 ='1') THEN IF (s1='0' AND s2='0') THEN conteo := conteo +1; ELSIF (s2='0' AND s3='0') THEN conteo := 0; ELSE conteo := conteo -1; END IF; q <= conteo; END IF; --PASO COMPLET0 CASE conteo IS WHEN 0 => csal <= "1010"; WHEN 1 => csal <= "1001"; WHEN 2 => csal <= "0101"; WHEN 3 => csal <= "0110"; WHEN 4 => csal <= "1010"; WHEN 5 => csal <= "1001"; WHEN 6 => csal <= "0101"; WHEN 7 => csal <= "0110"; END CASE; END PROCESS piso2; piso3:PROCESS (p3) VARIABLE conteo :INTEGER RANGE 0 TO 7; BEGIN IF (p3'EVENT AND p3 ='1') THEN IF (s1='0' AND s2='0') THEN conteo := conteo +1; ELSIF (s2='0' AND s3='0') THEN conteo := conteo +1; ELSIF (s3='0' AND s4='0') THEN conteo := 0; ELSE conteo := conteo -1; END IF; q <= conteo; END IF; --PASO COMPLET0 CASE conteo IS WHEN 0 => csal <= "1010"; WHEN 1 => csal <= "1001"; WHEN 2 => csal <= "0101"; WHEN 3 => csal <= "0110"; WHEN 4 => csal <= "1010"; WHEN 5 => csal <= "1001"; WHEN 6 => csal <= "0101"; WHEN 7 => csal <= "0110"; END CASE; END PROCESS piso3; piso4:PROCESS (p4) VARIABLE conteo :INTEGER RANGE 0 TO 7; BEGIN IF (p4'EVENT AND p4 ='1') THEN IF (s4='0' AND s5='0') THEN conteo := 0; ELSE conteo := conteo +1; END IF; q <= conteo; END IF; --PASO COMPLET0 CASE conteo IS WHEN 0 => csal <= "1010"; WHEN 1 => csal <= "1001"; WHEN 2 => csal <= "0101"; WHEN 3 => csal <= "0110"; WHEN 4 => csal <= "1010"; WHEN 5 => csal <= "1001"; WHEN 6 => csal <= "0101"; WHEN 7 => csal <= "0110"; END CASE; END PROCESS piso4; end Elevador;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 @E: CL219 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Multiple non-tristate drivers for net csal(3) in Elevador @E: CL219 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Multiple non-tristate drivers for net csal(2) in Elevador @E: CL219 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Multiple non-tristate drivers for net csal(1) in Elevador @E: CL219 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Multiple non-tristate drivers for net csal(0) in Elevador @E: CL219 :"C:\users\homero\documents\digital\elevador\elevador.vhd":8:1:8:1|Multiple non-tristate drivers for net q(2 downto 0) in Elevador @E: CL229 :"C:\users\homero\documents\digital\elevador\elevador.vhd":8:1:8:1|Unresolved tristate drivers for net q(2 downto 0) in Elevador @E: CL229 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Unresolved tristate drivers for net csal(2) in Elevador @E: CL229 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Unresolved tristate drivers for net csal(3) in Elevador @E: CL229 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Unresolved tristate drivers for net csal(0) in Elevador @E: CL229 :"C:\users\homero\documents\digital\elevador\elevador.vhd":9:1:9:4|Unresolved tristate drivers for net csal(1) in Elevador
