guyvaisman
Hello ,i'm new to hfss and this forum and i have a question that i hope will be answerd:
i'm trying to simulate a 20mm radius circular waveguide in hfss. i did a port solution only on the first 6 modes
and only the 3rd and the 6th mode made sense to me . that matched my analytical calculations concering the cut-off frequancies and the port field display matches the shape the electric field should be ( the 1st mode is a TM mode- the electric field is radial , and the 2nd one is a TE mode -the electric field is azimuthical).i've add the port field display images to make myself clear . it seems to me that i should be using only the 3rd and 6th modes. what am i doing wrong ?
thank alot !
guy .
thank alot !
guy .
