I2C interfacing problemeith eeprom 24c32a
pratheeshprm143
Newbie level 6
india
I2C interfacing problem with eeprom 24c32a
hai
I have interfaced an EEPROM 24C32A with 89c51.
I can send data into EEPROM, but can't read the same
this is my asm & circuit. Plz help me.............
SDA EQU P1.1
SCL EQU P1.0
ORG 00H
AJMP MAIN
ORG 30H
MAIN: MOV R7,#08H //SEND COUNT//
MOV R6,#08H //RECEIVE COUNT//
SETB P3.0
MOV R2,#32H //STORE RECEIVED DATA FROM EEPROM//
LOCK1: JB P3.0,LOCK1
;SJMP LOCK2
//32 BYTES CONTINEOUS WRITE//
ACALL I2C_START //START I2C//
//WRITES THE DATA INTO SLAVE//
ACALL I2C_CONTROL_BYTE_W //START+SLAVE ADDRESS+DEVICE SELECT+ACK//
ACALL I2C_SEND //SEND DATA TO SLAVE//
ACALL SLAVE_ACK_CHECK //WAIT FOR ACK FROM SLAVE//
ACALL I2C_ADDRESS_BYTE_H //HIGHER ORDER ADDRESS BYTE//
ACALL I2C_SEND
ACALL I2C_ADDRESS_BYTE_L //LOWER ORDER ADDRESS BYTE//
ACALL I2C_SEND
CONTINUE_T:
ACALL I2C_DATA
ACALL I2C_SEND
DJNZ R7,CONTINUE_T
ACALL I2C_STOP //STOP I2C//
LOCK2: JB P3.1,LOCK2
//READ THE DATA FROM THE SLAVE//
ACALL I2C_START
ACALL I2C_SEND
ACALL I2C_SEND
ACALL I2C_SEND
ACALL I2C_START
ACALL I2C_CONTROL_BYTE_R
ACALL I2C_SEND
CONTINUE_R:
ACALL I2C_RECEIVE
;ACALL MASTER_ACK
DJNZ R6,CONTINUE_R
ACALL I2C_STOP
HERE: SJMP HERE
I2C_START: SETB SDA
MOV R0,#0AH
MOV R1,#0AH
SETB SCL
DJNZ R0,$
CLR SDA
DJNZ R1,$
CLR SCL
NOP
NOP
RET
I2C_CONTROL_BYTE_W: MOV A,#0A0H
RET
I2C_CONTROL_BYTE_R: MOV A,#0A1H
RET
I2C_SEND: MOV R0,#09H
OUT: CLR C
RLC A
MOV SDA,C
NOP
NOP
SETB SCL
NOP
NOP
CLR SCL
DJNZ R0,OUT
NOP
NOP
RET
I2C_RECEIVE: MOV R0,#08H
IN: CLR C
RLC A
MOV C,SDA
NOP
NOP
SETB SCL
NOP
NOP
CLR SCL
DJNZ R0,IN
MOV SDA,C
ACALL MASTER_ACK
RET
SLAVE_ACK_CHECK: JB SDA,SLAVE_ACK_CHECK
RET
MASTER_ACK: MOV R0,#05H
CLR SDA
NOP
NOP
SETB SCL
NOP
NOP
CLR SCL
NOP
NOP
DJNZ R0,$
SETB SCL
RET
I2C_ADDRESS_BYTE_H: MOV A,#00H
RET
I2C_ADDRESS_BYTE_L: MOV A,#00H
RET
I2C_DATA: MOV A,#11H
NOP
RET
I2C_STOP: CLR SDA
MOV R0,#07H
SETB SCL
DJNZ R0,$
SETB SDA
RET
ENDdesign_I2C.pdf
If you are doing byte read then try to read with NACK..
If sequential read then all other read with ACK except last one, that one should be read with NACK...
Amit
** If you find my answer useful, please click the "Helpful? Please click" icon. **
try this code. It works.
