balaece07
Newbie level 2
Urgent!!!
HI EVERYONE,
BALA Here.I am trying to communicate TWO 89s52 Microcontroller Using I2C..I tried So many Times....But Didnt get the output..
Here I am Including My code..Pls find the mistake and Help me..
Tahnks in Advance
code:
#include<AT898252.h>
#include<intrins.h>
unsigned char readI2c(bit ACK_Bit);
void writei2c(unsigned char W_Byte) ;
void writemc(unsigned char addr, unsigned char data1);
void readmc(unsigned char addr);
sbit SDA = P0^1; // connect to SDA pin (Data)
sbit SCL = P0^0; // connect to SCL pin (Clock)
delay();
void main()
writemc(0x24,0x55);
readmc(0x24);
// start I2C
void Start(void)
SDA = 1;
SCL = 1;
_nop_();_nop_();
SDA = 0;
_nop_();_nop_();
SCL = 0;
_nop_();_nop_();
// stop I2C
void Stop(void)
SDA = 0;
_nop_();_nop_();
SCL = 1;
_nop_();_nop_();
SDA = 1;
// Write I2C
void writei2c(unsigned char Data)
unsigned char i;
for (i=0;i<8;i++)
SDA = (Data & 0x80) ? 1:0;
SCL=1;
SCL=0;
Data<<=1;
delay();
SCL = 1;
_nop_();_nop_();
SCL = 0;
// Read I2C
unsigned char Data=0;
unsigned char i;
SDA = 1;
for (i=0;i<8;i++)
SCL = 1;
Data<<= 1;
Data = (Data | SDA);
SCL = 0;
_nop_();
delay();
if (ACK_Bit == 1)
SDA = 0; // Send ACK
else
SDA = 1; // Send NO ACK
_nop_();_nop_();
SCL = 1;
_nop_();_nop_();
SCL = 0;
return Data;
Start();
writei2c(0xC0);
writei2c(addr);
writei2c(data1);
Stop();
void readmc(unsigned char addr1)
unsigned char rdata;
Start();
writei2c(0xC0);
writei2c(addr1);
Start();
writei2c(0xC1);
rdata=readI2c();
Stop();
P2=rdata;
delay() /*One Second Delay*/
T2MOD=0x03;
TL2=0xFC;
TH2=0xFE;
TR2=1;
while(TF2!=1);
TR2=0;
TF2=0;
HI EVERYONE,
Tahnks in Advance
code:
#include<intrins.h>
delay();
void main()
writemc(0x24,0x55);
readmc(0x24);
// start I2C
void Start(void)
SDA = 1;
SCL = 1;
_nop_();_nop_();
SDA = 0;
_nop_();_nop_();
SCL = 0;
_nop_();_nop_();
// stop I2C
void Stop(void)
SDA = 0;
_nop_();_nop_();
SCL = 1;
_nop_();_nop_();
SDA = 1;
// Write I2C
unsigned char i;
for (i=0;i<8;i++)
SCL=1;
SCL=0;
Data<<=1;
delay();
SCL = 1;
_nop_();_nop_();
SCL = 0;
// Read I2C
unsigned char i;
SDA = 1;
for (i=0;i<8;i++)
SCL = 1;
Data<<= 1;
SCL = 0;
_nop_();
delay();
if (ACK_Bit == 1)
else
_nop_();_nop_();
SCL = 1;
_nop_();_nop_();
SCL = 0;
return Data;
Start();
writei2c(0xC0);
writei2c(addr);
writei2c(data1);
Stop();
Start();
writei2c(0xC0);
writei2c(addr1);
Start();
writei2c(0xC1);
rdata=readI2c();
Stop();
P2=rdata;
T2MOD=0x03;
TL2=0xFC;
TH2=0xFE;
TR2=1;
while(TF2!=1);
TR2=0;
TF2=0;
